98 XJ8 coolant light, possible cause
Old May 19, 2009 | 05:57 PM
XJ ate's Avatar
Default 98 XJ8 coolant light, possible cause
I had my low coolant light on fore a couple months and could never figure out why it was on. I checked the coolant many times and it was never low. I checked the float and it was working properly. So I decided to not worry about it. Well I had to replace a fuel pump and after doing so I was putting the plastic back on the top of the motor after testing the pressure at the fuel rail and saw this lil guy hanging from below the coolant tank. I put it back in the hole it was falling out of and it clicked into place. Since then no issues with the light, its off and has not came back on yet so that must have been the issue.
Can anyone tell me what it is called or what it does? Is it the pole that the float rides on and if so why did the float seem to work okay?
Attached Thumbnails 98 XJ8 coolant light, possible cause-jag-coolant-probe.jpg
Old May 19, 2009 | 09:30 PM
remosusa's Avatar
It's the coolant sensor. The float closes the circuit around the sensor, if the coolant is full. It just snaps in.
Old May 19, 2009 | 10:54 PM
XJ ate's Avatar
cool, thats what I though. Thanks. Hopefully this helps someone else. Ive heard a few coolant lights on for no reason around here.
Old May 20, 2009 | 07:38 PM
still_rubbin1's Avatar
where is this loacted at ....mine is on as well and i cant seem to figure it out
Old May 20, 2009 | 08:47 PM
wazari's Avatar
Where 1 is pointing to on your expansion tank.
Old May 20, 2009 | 09:26 PM
thanks
KarimPA
Sep 12, 2015 08:15 AM
jimmiejag
Sep 9, 2015 02:56 PM
OkieTim
Sep 8, 2015 04:48 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
