98 xj8 p1396
Old Sep 8, 2008 | 10:12 PM
oldmots's Avatar
Default RE: 98 xj8 p1396
You will need ot go to Alldata.com for the test sequence for this code on the VVT actuators. There are too many things to type and it cannot be copied due to copyright. It is possiblean actuator coil is bad or a connector is not making contact, you can testthem easily.
Old Sep 10, 2008 | 04:43 PM
ken@britishparts.com's Avatar
Make sure the VVT is throughly cleaned. The spring won't work if it's sludged up with oil. You can use some pretty harsh solvents. No rubber parts inside to damage.
Old Sep 11, 2008 | 08:42 PM
oldmots's Avatar
You must have missed tests C2 and C4, the coil resistance test and check on EMS1 relay. You also missed test C9 for testing for debris in the oilpassageway.The problem is very likely one of these. Be sure to read the test sequences thoroughly.
magmedia
Oct 8, 2015 03:28 PM
freddieg
Oct 6, 2015 11:23 AM
mat32essex
Oct 3, 2015 04:12 PM
kingdom worker
Oct 2, 2015 05:43 AM
donald ebanks
Sep 30, 2015 07:08 PM
