98 XJR Engine Rebuild
Old May 24, 2025 | 02:29 PM
Ant305's Avatar
Default Supercharger Coating peeling?
while I was cleaning the rotors of the supercharger I noticed some sort of coating coming off the rotor.
Can see it a lot better in
Should I be concerned?
Im sending the supercharger to powerhouse in a month or 2 would they be able to fix this?
Old May 24, 2025 | 04:00 PM
NBCat's Avatar
Have the supercharger rotors recoated and change the oil.
Old May 24, 2025 | 04:01 PM
NBCat's Avatar
Make sure you time the camshafts correctly using the holding tools. Contrary to popular thinking, the camshafts are NOT set to TDC, but to 45 degrees ATDC.
Old May 24, 2025 | 10:39 PM
Ant305's Avatar
Would I still be able to drive the car with the supercharger for the time being?
I believe I did everything correct for the timing. I turned the engine over a few times to verify there was no contact after everything was set.
Old May 25, 2025 | 03:09 AM
Cafcpete's Avatar
Can see it a lot better in THIS VIDEO
Talk to Magnumpowers, they can re coat for you.
https://magnumpowers.com/services/
Old Jun 7, 2025 | 04:49 PM
Ant305's Avatar
Default Final Question Before I start it
When I removed the trans cooler line roughly a quarter of a quart (probably not even that) fell out.
I was wondering if this should be topped off or would I be fine to drive it until I’m able to do a full transmission flush.
Old Jun 7, 2025 | 05:21 PM
motorcarman's Avatar
Why not check the level with the Mercedes tool?
Old Jun 7, 2025 | 05:34 PM
  #28
Ant305's Avatar
was unaware of such a tool. Haven’t looked in the transmission all too much.
Could you provide a part number for it ?
Old Jun 8, 2025 | 06:20 AM
Highhorse's Avatar
They are all over ebay and amazon, just type in 722.6 transmission dipstick
KTMTech
Apr 13, 2019 10:50 AM
hstovall1
Dec 13, 2017 03:35 PM
Jeffer
Dec 20, 2015 02:36 AM
avt007
Jun 27, 2013 12:28 PM
John Fox
Sep 22, 2011 09:37 AM
