98xj8 starts,stops
Old Jan 25, 2013 | 11:57 AM
Celeta Moses's Avatar
Default 98xj8 starts,stops
my 98xj8 (61k miles) fussed a little starting - had to pump the accelerator once - got going - every thing fine. Now, it starts then dies. The battery
is new, and it has fuel. any ideas? Thanks
Old Jan 25, 2013 | 01:05 PM
I've moved your thread from General Tech Help section to X308 section for input from members with the same model.
Old Jan 25, 2013 | 03:17 PM
RJ237's Avatar
As always, there are many possibilities. One is that the fuel pump is failing or the fuel filter needs changing. It is necessary to check the pressure at the fuel rail. We do not know your circumstances as regards mechanical experience or if you have a local shop that does your repairs and maintenance.
Old Jan 25, 2013 | 03:20 PM
dsnyder586's Avatar
I would start with changing the fuel filter- cheap and easy.
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Bones
Sep 8, 2015 08:34 PM
tberg
Sep 7, 2015 07:32 AM
