99 jag VDP stuck in park
Old Aug 26, 2013 | 08:08 AM
pirat3120's Avatar
Default 99 jag VDP stuck in park
Replaced battery in jag everything thing works but the security system and stuck in park. also the red light is on in the speedometer in the dash no codes. does the security system not coming on have anything to do with car stuck in park??? how do I get car in neutral??? can anyone help please
Old Aug 26, 2013 | 02:30 PM
runnerpaul's Avatar
Default See link below
Hi,
Try this link, it points to a short somewhere:
https://www.jaguarforums.com/forum/x...ck-park-94590/
Also try a hard reset by dis-connecting both the battery positive and negative cables from the battery and touching them together for about a minute. Here's the link for a hard reset https://www.jaguarforums.com/forum/x...d-reset-38112/
Is the battery fully charged?
Last edited by runnerpaul; Aug 26, 2013 at 03:29 PM. Reason: Added Hard Reset Link
Old Aug 28, 2013 | 06:58 PM
Lear45's Avatar
I am not sure, but I think the torx fastener by the shift lever allows going into neutral.
Check the owners manual.
Old Aug 28, 2013 | 10:05 PM
motorcarman's Avatar
Yes the plastic blanking plug can be removed with a T30 Torx and the ignition key inserted to release the selector lever from PARK.
Move the lever to NEUTRAL, pull the key from the hole and start the engine. Do not put it in park until you are done driving or go through the release procedure again.
bob gauff
Old Aug 28, 2013 | 10:16 PM
plums's Avatar
bob gauff
Think I'll go loosen mine in case of a rainy day
Old Aug 28, 2013 | 10:29 PM
I loosened both of my XJ8s selector lever release blanking plugs so that I could use a flat blade screw driver or maybe even my finger in case I needed to.
I hate to press my thumb on them and they just tear the skin up and leave a red mark.
When I worked at the Jag dealer we used to get cars from used car dealers that came from the auctions. The batteries would go dead and lock the selectors in PARK.
The car jockeys at the auctions learned to just yank the levers FAST AND HARD to break the plastic selector housing to release the gearbox so they could push the car out into the open. I guess they did not carry a TORX 30 to remove the plug.
I got pretty good at replacing the plastic housings and bent levers.
bob gauff
Bcrary3
Sep 12, 2021 05:41 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
