99 jag XJR battery drain
Old Jun 26, 2014 | 10:47 AM
WILD4452's Avatar
Cool 99 jag XJR battery drain
new battery.when running metor shows 12.40 at the highest.new starter.battery charged two days ago.checked today before start.12.13 v after start would only go up to 12.40 v.im not sure but i would think it should go higher. thanks for any help
Old Jun 26, 2014 | 10:53 AM
Welcome to the forum WILD4452,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Jun 26, 2014 | 12:25 PM
margate69's Avatar
So after the vehicle starts, the voltage never goes about 12.4? If that is the case, that alternator is either not charging, or the voltage is dropping off before the battery. Check the charging at the terminal on the back of the alternator. If the voltage there is only 12.4 volts, the alternator is bad. If it is 14-15v, you have to find where you are losing the voltage.
allenman85
May 10, 2021 03:11 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
XFR_Gold
Sep 2, 2015 12:24 PM
Thia
Sep 1, 2015 10:36 AM
