99 vanden plas
Old Jun 22, 2007 | 10:57 AM
ken@britishparts.com's Avatar
Default RE: 99 vanden plas
Try swapping the misfire coil with one of the known good ones. See if the problem moves with the coil. Perhaps you got a bad one. Not likely, but easy to rule out.
Old Jun 24, 2007 | 07:03 AM
04Xtype's Avatar
I had a similar problem with the S-type R. Had a misfire on 6 and 7. When i pulled the plugs out it looked like they had oil on em, so i took it to the dealer, and they told me that there could be something wrong with the compression and possibly need a new engine. I decided to take the car home after paying $150 for a diognostic check, and changed all the plugs, and the coils for 6 and 7. After this the problem went a way and the car run fine. Hope this helps and hope ure problems resolved soon.
Old Jul 7, 2007 | 06:07 PM
jag_genius's Avatar
sounds like your secondary timing chain tensioners have fallen apart.. remove cam covers and take a peek... cam's won't be timed due to the failure of the tensioner...
Old Jul 7, 2007 | 06:08 PM
jag_genius's Avatar
you shud take it to a dealer... special tools are required to set the timing...
Old Jul 9, 2007 | 05:48 PM
Look around first. You can find the timing tools in the aftermarket.
Old Jul 9, 2007 | 07:28 PM
jag_genius's Avatar
true but only people who have done this before shud attempt... no back yard repair...lol
Brewmonkey
21
May 30, 2016 12:50 AM
JungleJonny
Oct 5, 2015 03:52 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
42Ajd
Sep 26, 2015 07:04 PM
