99 VDP Electrical
Old Jul 15, 2014 | 12:50 PM
TheHilds's Avatar
Default 99 VDP Electrical
I am currently having a electrical issue with 3 different items and am unclear if they are related. If anyone can point me in the right direction as to where I can look or meter for clarification?
1. My starter is slow cranking.
2. Windshield wiper arm moves aprox 1/2" then stops.
3. Passenger door lock will not lock anymore.
Old Jul 15, 2014 | 01:14 PM
jimbov8's Avatar
Hi David,
1. Check/charge battery then clean and tighten connections on stater motor.
2. Remove wiper arms and motor. Check linkages and lubricate. Strip down motor, lubricate moving parts, reassemble and bench test.
3. Remove door card. Check linkages and lubricate. Test micro switches for correct operation. May need a new switch or mechanism.
All of above will cost nothing more than time and patience.
Hope this helps,
Old Jul 15, 2014 | 01:17 PM
RJ237's Avatar
Start by having the battery load tested at one of your neighborhood parts stores. Also have them check for codes, but report the codes here, don't go by what the generic code reader says.
Old Jul 15, 2014 | 02:06 PM
TheHilds's Avatar
All good suggestions, Thank you. I will check these this week and post my findings to update. Thank you again.
Old Jul 15, 2014 | 04:43 PM
avt007's Avatar
Follow the electrical link in my signature, it will help you track down the starter issue. I think the other two are unrelated. Are there any other issues?
Old Jul 15, 2014 | 05:02 PM
TheHilds's Avatar
No other issues that are apparent at the moment but it seems as every time I fix one 2 more show up. I guess that is the game we play when restoring cars right!
Old Jul 15, 2014 | 05:21 PM
avt007's Avatar
Check out this thread, it ma help on th wiper thing, at least you can eliminate a grounding issue.
https://www.jaguarforums.com/forum/x...s-help-110832/
Old Jul 24, 2014 | 01:45 PM
TheHilds's Avatar
I checked the grounds in the link you sent ATV007 and they are all good. Prior to these issues I was tracing vacuum lines and I replaced the upper bank 1 O2 sensor. In order to do this I needed to remove the Throttle Body, is there a possible ground that I could have removed and not realized in that area?
Old Jul 25, 2014 | 10:33 PM
Lear45's Avatar
Jagrepair.com has the entire wiring diagram manual. At great resource. Go to the site and click on Electrical, OBD Codes section, the first manual under that title. Memorize
it and then come back to the forum and teach the rest of us.
Electrical, OBD Codes,
Tech Guide & Spec Book
Technical Service Bulletins (TSB) Jaguar XJ8 XJR 1998-2003
Jaguar XJ8 XJR 2004-Newer
Jaguar XK8 XKR 1997-2006
Jaguar XK XKR 2007-Newer
Jaguar XJS
Jaguar S-Type
Jaguar X300
Jaguar XJ40
Jaguar XJ6 & XJ12
Jaguar X-Type
hkmcmast
Nov 29, 2015 06:56 AM
freddieg
Oct 6, 2015 11:23 AM
k-man
Oct 5, 2015 08:09 AM
freddieg
VENDOR 'For Sale' Classifieds
Sep 29, 2015 07:13 PM
