'99 XJ8 Rear Shock Replacement
Old Dec 9, 2017 | 03:03 PM
dude1579's Avatar
Default '99 XJ8 Rear Shock Replacement
I am in the process of replacing the rear shocks on my Jag. My question is: How do I access the nuts/bolts at the top of the shocks to remove? I don't see access through the trunk. Does the rear seat need to be removed? Thank you!
Old Dec 9, 2017 | 03:08 PM
King Charles's Avatar
Here's the detailed process.
https://www.jaguarforums.com/forum/x...emoval-185520/
http://jaguar.blackonyx.net/tech/rearshocks.pdf
Old Dec 11, 2017 | 04:00 PM
dude1579's Avatar
Thank you, King Charles. The links you provided were very descriptive and helpful. I will tackle the problem shortly.
Old Dec 14, 2017 | 10:30 AM
Ric in RVA's Avatar
Only issue I ran into is that the sleeve in the lower shock mount will weld itself to the bolt.
The bolt will then spin in the mount and the two shall never come loose.
I heated, ground through the shock eye into the sleeve along its length. Still not loose.
Eventually used a metal cutting sawzall and went across bolt at each side of the shock eye.
Had to get a new bolt.
Other than that a piece of cake.
Also you don't have to get the whole shock assembly out as a unit. You just need to get to the hardware on top to R&R the upper shock bolt.
Old Dec 27, 2017 | 11:18 AM
dude1579's Avatar
Ric in RVA - Just to confirm that I had the exact same problem with the lower bolt welding itself to the sleeve. I had minimal success using torch heat. My impact wrench barely nudged the bolt. Since I did not have a bunch of room to work under the car, I ended up paying to have the bolt extracted. Sheesh... The opposite side was a piece of cake. Go figure. Thank you for your comments.
Old Dec 27, 2017 | 12:56 PM
Ric in RVA's Avatar
I bet that happens a bunch with the dissimilar metals they are using. Bet it rides nice now!
apexjag
Sep 24, 2019 12:52 AM
casualcat
Jun 20, 2015 10:00 AM
H20boy
General Tech Help
Oct 31, 2010 08:27 PM
user 2029223
Oct 30, 2010 03:04 AM
SilverXJ
Feb 12, 2010 08:11 PM
