99 XJ8 VDP: Such a little thing causing such a big problem
Old Jun 28, 2013 | 02:34 PM
BillDJohnson's Avatar
Question 99 XJ8 VDP: Such a little thing causing such a big problem
I rarely even try to use the key to lock or unlock my door. Partly because using it to unlock the door sets off the alarm immediately. However, I've also found that I cannot lock the door with the key. It simply won't turn (toward the front of the vehicle - counterclockwise).
I think it worked when I bought the car, but shortly afterward I messed with the lock actuator and rods (to replace the interior latch cable). As far as I could tell, everything got put back the way it was supposed to be, but I'm wondering if something small dropped into the mechanism and has the key mechanism wedged.
Any ideas or advice would be greatly appreciated!
Old Jun 28, 2013 | 10:34 PM
Tirefriar's Avatar
Need to go back in and check the actuator
Old Jun 30, 2013 | 03:51 AM
osyris's Avatar
its always wise to apply silicon grease to all mechanisms.
Did you not test the locking mechanism when you reinstalled all the gear in the door/. Did it work then.. if not maybe it needs to be redone properly... may just need some grease.
best
Peter
Old Jun 30, 2013 | 02:22 PM
avioni's Avatar
I agree with above. Plus silicone grease makes wonders. I ise it for window mechanism. Motors. Anywhere there should be minimum friction
Old Jul 1, 2013 | 09:36 PM
Thanks, everyone, for your comments.
A correction to my initial post:
It turns out that I CAN lock the vehicle with the key. I can also hold the key in the lock position and it will close any opened windows and the sunroof.
The main problem continues to be that when I unlock the car with the key (and it does unlock), the alarm sounds immediately. So, it appears that there are no mechanical movement problems that could be fixed with grease, just a problem with the alarm triggering.
BrentGardner
29
Dec 16, 2024 12:13 AM
XFR_Gold
UK & Eire
Sep 2, 2015 06:30 AM
Jandreu
Aug 29, 2015 07:31 PM
DeaconHull
Aug 28, 2015 05:26 PM
Will P
Aug 27, 2015 06:52 PM
