99' XJ8 Wierd Sounds and Stalling......HELP!!!
Old Nov 9, 2008 | 10:19 AM
atom069's Avatar
Default RE: 99' XJ8 Wierd Sounds and Stalling......HELP!!!
First thing you can do is read up, that info is all over this site, as that's what most of the problems are for peeps. If you read, you will save a lot of money, time, and stress.
Sorry dude either your throttle body is dirty or has mismatched TPS pins (nickle to gold) like mine was and it stalls every once in a while, andor you're about to experience a tensioner brake/possible chain break. That ticking is the timing chain (probably secondary) on the rotation. My old 98 did the same thing before I did the tensioner job,it wouldn't even start over a lot of times, when it does that you should NOT try to restart it,but hey I did! hah.. Goodluck
Old Nov 10, 2008 | 09:28 AM
stkxjrtech's Avatar
im slightly leaning toward the chains also. does the knocking noise change pitch or loudness as it goes from a cold start to slowly gaining oil pressure?
CClifton
Mar 19, 2017 02:25 PM
mls0036
Oct 17, 2015 10:03 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
corysansburn
Sep 10, 2015 06:15 AM
wcourt3010
Sep 9, 2015 04:34 PM
