Abnormal amount of Oil in intake pipe
Old Nov 27, 2012 | 06:24 PM
Safi's Avatar
Default Abnormal amount of Oil in intake pipe
so went to replace the spark plugs, and while i had the intake pipe off i noticed a lot of oil in the pipe, a little in the bottom of the intake box, and a lot around the throttle body, what should i do to fix this?
http://www.flickr.com/photos/undertaker414/8222419725/
Old Nov 28, 2012 | 05:09 PM
Rey's Avatar
Rey
You didn't tell us anything about the car. Looking at your post, I assume it is a 2000 XK8. There is a more specific forum for your car that you might check.
Just how many miles are on your car? Are you checking the dipstick; and, if so, how is your oil consumption?
Old Nov 28, 2012 | 09:23 PM
Safi's Avatar
2000 XJ8 with 86k on the clock, and the oil is fine, dark but fine
Old Nov 29, 2012 | 10:54 AM
Fishfoolbear's Avatar
I looked at my air intake pipe because my fuel trims were quite a ways negative and found a lot of oil in there too, also the filter was oily below the intake pipe, as if the oil had dripped onto it (filter was new 1000km before), the pipe picture is upside down
So I read a little bit here and figured it might be a blocked part load breather, as the full load breather was not blocked.
I cleaned that with a drill bit in a hand-held bit holder and cleaned the MAF. Since then my fuel trims are back to approxiamtely zero and I'm using about 2-3 l/100km less :-)
Could be worth looking at. Have a search for the TSB on part load breather cleaning, its a bit of a PIA but had a huge affect on my car.
Lincoln
Attached Thumbnails Abnormal amount of Oil in intake pipe-foto.jpg   Abnormal amount of Oil in intake pipe-foto_filter.jpg
aholbro1
Dec 29, 2024 06:46 PM
xjrjag
Oct 24, 2024 03:09 PM
1100me
Jul 24, 2023 06:10 PM
Daim
Nov 28, 2016 09:28 AM
Gerard Radimaker
Sep 13, 2015 10:33 AM
