abs warning and trac/and asc failure light on
Old Oct 29, 2008 | 11:45 PM
Sarc's Avatar
Default RE: abs warning and trac/and asc failure light on
I've had the same thing 3 times now, and it's always correlated to hitting a pothole. I guess I may have a slightly loose connector somewhere that gets upset when the wheel (always the left front) goes down a hole in the road (There are lots here in Cali)
The fix is the same everytime. Stop at the next traffic light (again, there are many in Cali). Switch off, restart and all is well again.
Old Oct 30, 2008 | 10:52 AM
ken@britishparts.com's Avatar
The connector is a possiblity, also a bad wheel bearing can cause this. Wheel bearings fail regularly on the XJ and XK models. We sell the nut removal tool for $150. Also, a bad ABS sensor could be at fault. They are expensive, but don't worry, we don't sell many of those. Start with your wiring idea. It's least expensive.
Old Nov 2, 2009 | 11:31 AM
SuperSport's Avatar
Hey SARC, I'm just starting to get the PotHole Issue. Did you ever find a definitive fix for this? I've been doing the stop and restart "fix", but I don't want to be stranded away from home some day.
Thanks for your input.
Old Nov 2, 2009 | 08:01 PM
sparkenzap's Avatar
Or get someone with the factory or AutoEnginuity Jag specific software to interrogate the ABS module for codes. Then solve the problem it points to.
Old Jun 17, 2015 | 03:15 AM
Michael Awford's Avatar
Default Usually a false alarm
I've had this warning come up sometimes with my last 3 XJRs, at first it worried me, now I just ignore it, since it goes away when you stop and restart, and ABS worked normally (I did a test on a gravel surface and it chuntered away happily). But I'm no expert, so get it checked just to be sure.
Old Jun 17, 2015 | 04:22 AM
Originally Posted by Michael Awford
I've had this warning come up sometimes with my last 3 XJRs ..........
Welcome to the forum Michael,
Old Jun 17, 2015 | 04:59 PM
Jhartz's Avatar
But, maybe, you didn't notice,Michael, but you are answering someone's concern from Nov 2009; six years ago. I bet they don't have the car anymore!
Old Jun 18, 2015 | 01:13 AM
  #28
Actually it was 2007 but I only joined the forum to see if there was a remedy for an annoying warning, and I'm sure there are other CURRENT owners with same problem. Your comment was irrelevant and a bit irritating and a bad start to my joining the forum.
Old Apr 20, 2025 | 03:00 AM
Raymondo the Unbelievable's Avatar
Default ABS fail light
Error lights came on and stayed on. Using ICARSOFT V2 diagnostics tool while wifey drove, all sensors appear to be correctly reading wheel speed. I guess I need a replacement ABS module.
Old Apr 21, 2025 | 01:52 PM
  #30
Throwback's Avatar
Well known issue with these modules is that the solder on the circuit board fails and causes an abs pump failure DTC code in the diagnostics tool. What code did you get? its a relatively easy but involved (multi-step) problem to solve and you gotta be comfortable with bleeding brakes, handy with a dremel, and ok-ish at soldering.
Old May 16, 2025 | 04:56 PM
  #31
Vinman's Avatar
Originally Posted by jag_genius
9 times out of ten you need a ABS MODULE ..$1800.00 or get it rebuilt... or i can rebuild it... if you scan for codes you'll find C1095
What scanner tool will work on that year and model. I have a 1998 Jaguar xj8
Old May 17, 2025 | 09:44 AM
  #32
RandyS's Avatar
Well Vinman...it really depends on what level of diagnostic data you require. In some
cases a simple ELM327 with an app you have selected for your phone will do and in other
cases a member may need more specific data to discern a given problem.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
avern1
Sep 8, 2015 06:25 PM
