ac charge
Old Jul 4, 2011 | 10:40 AM
nsrt4's Avatar
Talking ac charge
98 xj8
the system was evacuated a while back while the car had a major engine overhaul so now im vacuuming the whole system and im having trouble finding the correct ports.
while looking online i found this diagram and i got a couple of questions for you xj8 gurus.
are the ports labeled backwards?
how much freeon does the system take?
28oz?
what pressures should i look for while refilling with outside temperatures?
30-40 psi on low pressure side?
what about high pressure side?
98+xj8+engine+diagram | Car Parts Diagram
Old Jul 4, 2011 | 12:13 PM
Dinger's Avatar
The system takes 650-700 grams of R134a. Freon is the old name for R12 which is no longer used.
You are looking at about 50psi low side and up to about 250psi high side.
Old Jul 4, 2011 | 02:03 PM
test point's Avatar
JTIS section 412.00 has the AC information. Attached is the ambient temp chart clipped from it. Temperature makes a huge difference.
The drawing legend appears correct.
Old Jul 5, 2011 | 09:24 AM
ronmexico's Avatar
Definitely use a manifold gauge set to charge it properly. You can get them pretty cheap now....
JTIS has graphs for the ambient temperature versus pressure, don't have JTIS handy now otherwise I would post it....
After I tuned my Jag A/C up properly; 85 degrees outside, driving down the road, my AC vents were blowing 37 degree air out... :-)
Old Jul 5, 2011 | 12:22 PM
nsrt4's Avatar
yes i meant r134a when i said freon
Old Jul 5, 2011 | 12:27 PM
nsrt4's Avatar
while filling up the system it was 95 out here in myrtle beach sc i stoped filling the system at 45low side 250+ high side using the manifold gauge and 12oz cans. its cooling now finally
650-700grams is 22-25oz
thanks for the help
jluckcuck
Nov 6, 2015 07:49 AM
10 XF Premium
Oct 2, 2015 09:22 PM
oldjaglover
Sep 29, 2015 03:27 PM
PinnacleWax
Detailing / Car care
Sep 25, 2015 12:46 PM
