Adjustable gaz shock absorber damper suspension
Old Jan 31, 2023 | 04:16 PM
vincent661983's Avatar
Default Adjustable gaz shock absorber damper suspension
Hi to all
all shocks are original to my 2000 XJR. it is finally showing its age and the rear end suspension is developing some loose noise.
I decided to give a try to this shock set. just placed the order and takes a few weeks to build
will keep every one posted.
https://www.ebay.com/itm/22500921917...&segname=11051
Old Feb 1, 2023 | 06:55 AM
Z07Brandon's Avatar
Nice! I look forward to your review.
Old Feb 1, 2023 | 09:31 AM
Vauxi's Avatar
My other british car has gaz gt in all corners with std springs. Car is pretty light weight but shocks are very coarse in adjustments. On top of that the shocks are pretty surface stiff to drive and no progressive damping at all. By surface stiffnes I mean not turned too stiff, but all around stiff. These can be adjusted up to no dampning at all.
But if that is not a bad thing, then these are okay shocks. Maybe with stiff springs these work better. But still no progressive dampning.
Old Oct 8, 2024 | 12:19 PM
jasperwatson's Avatar
Originally Posted by vincent661983
Hi to all
have you had any further thoughts on this set?
DaveinG
Oct 24, 2022 04:52 AM
mscott
Aug 3, 2020 04:00 AM
alatoni14
Aug 12, 2017 10:03 AM
jagmanv8
Jun 18, 2017 07:03 PM
johnleavitt
Oct 3, 2011 07:12 AM
