allignment issue X308
Old Aug 31, 2020 | 04:13 PM
Xjr400hp's Avatar
Default allignment issue X308
Hello Guys, My XJR X308 finally done, well from timing tuneup to suspension! but still facing allignment issues, took it to a laser machine shop but they asking to bring camber bolts kit,
Is there any shop who can work on jaguar allignment near dallas fort worth,texas or any place i can buy camber bolts ??
thanks in advance!
Old Aug 31, 2020 | 04:48 PM
aquifer's Avatar
What made them think that the bolts are bad? The bolts just have an offset washer and don't really have much wear and tear. It is more likely to be worn bushings or ball joints that prevents the shop from being able to adjust it into proper alignment. Shocks matter too. In my case, the subframe bushings were also shot so I dropped the subframe down and replaced the bushings and motor mounts. After that, the local shop had no trouble aligning it. It's been a while since I redid the front suspension on my car, but I'm pretty sure that the coil springs have to come out before you can replace any of the bolts. If you're that far into it, replacing the bushings and ball joints seems logical.
If there is a specific reason that they think you need new bolts, then disregard what I said. Otherwise, I think you need to look a little deeper. That was my personal experience, anyway. Good luck.
Old Aug 31, 2020 | 05:16 PM
Xjr400hp's Avatar
yeah i replaced everything! i mean i bought this car 15 years ago with 100k bumper to bumper warranty. since then auto bahn fort worth replaced front springs and frame bushing ( eight years ago but only put 2000 miles since) then i replaced complete front bushing, tie rods, shocks mounts and motor mounts.
Old Sep 2, 2020 | 01:25 PM
hispeed42's Avatar
PM motorcarman; if you're using a shop over in Fort Worth anyway, it's not that much farther to Decatur and you would have a very knowledgeable forum member!!
Old Sep 2, 2020 | 01:37 PM
motorcarman's Avatar
Thanks but I DON"T HAVE ALIGNMENT EQUIPMENT.
Being mostly retired I have no interest in buying an alignment machine.
I did take one of my X308s to Superior Auto in Decatur after a suspension rebuild a few months ago.
They have modern alignment equipment and are about 15 miles from me.
I have not done alignments since I left the dealer in 2006.
Old Sep 2, 2020 | 03:16 PM
hispeed42's Avatar
Oops!!! Didn't know that you retired.
Old Sep 2, 2020 | 03:36 PM
I'm not completely retired (I do like to work on one or two a week) but I don't do the 40 hour weeks anymore.
Alignment equipment takes up a lot of space in a shop so it has to be used to pay for itself.
My shop is only 1500 Sq Ft so I only have two lifts.
I like a slow pace lately.
Old Sep 2, 2020 | 04:48 PM
Highhorse's Avatar
Damn Bob, that means the living room and dining room for the house are the shop floor and the other is the bedroom/break room. The kitchen, I'll bet, has the balancing machine.
Old Sep 2, 2020 | 08:41 PM
My house (the wife's domain) is over 2000 sq ft so she has more room than me!!!!!
Old Sep 2, 2020 | 09:34 PM
pdupler's Avatar
To be obsessive-compulsive, by-the-book, I bet you are probably supposed to replace just the locknut. If I remember right its a nylock type. Bob probably could confirm. But that shouldn't be a Jaguar special order thing. However, I've never had an alignment shop insist that I bring them new locknuts.
Old Sep 3, 2020 | 09:12 AM
XJR RONN's Avatar
Me Too !
Mostly retired this year . Finally getting around to all my OWN car projects. Finally time to do things the way you know they should be done and not worry about time efficiency .
Old Sep 3, 2020 | 09:34 AM
sgfeld1693's Avatar
Default Repair shop
thanks in advance!
I don’t know anything about this shop but I saw it next to the Gas Monkey garage when we visited there. I also have a XJR so I kept this garage in mind in case I needed something.
Old Sep 3, 2020 | 09:54 AM
hispeed42's Avatar
The only suspension bolts that I have had to replace were the lower ones on the rear shocks as they had seized up. And the only alignment issues were when I tried the urethane bushings from Paramount when they first came out several years ago. The inner sleeves were one or two mm's too big and they would slop around. The Paramount roll bar bushings fit and they're still on there and looking good.
Old Sep 7, 2020 | 08:20 PM
Xjr400hp's Avatar
yeah sure im not that far.. i forgot to mention that i also removed drive shaft to replace fuel pumps, that could be the reason that car wobbles?
Old Sep 8, 2020 | 11:01 AM
Highhorse's Avatar
You may want to review this How To... https://www.jaguarforums.com/forum/x...pshaft-207717/
Old Sep 13, 2020 | 05:48 PM
len1957's Avatar
Default Diy alignment
So tried finding someone competent to set my front end up but not impressed with the mumbling I was hearing !, so made my own gauges and stands I already have a diy laser tracking tool and got toe perfect(.05) toe in, but struggled with camber!, only to find a worn cam plate (have you seen the price of those!, ). Looks like the we alder coming out again! Ha ho.
Count Iblis
Jan 3, 2023 03:32 PM
XJ8Lou
Oct 22, 2019 06:52 PM
Steve W
Jan 29, 2018 11:02 PM
vdpnyc
May 15, 2016 08:54 PM
