Another Trnasmission Problem
Old May 31, 2008 | 11:52 PM
Rock Meathammer's Avatar
Default RE: Another Trnasmission Problem
Try to get the code from the transmission fault. If it isn't a major problem, the fault code will just reset with the restart of the vehicle. If the code and problems remain indefinately, and the trans stays in limp mode (3rd gear) you most likely broke a drum. And if you have driven the car in limp mode for a little bit, you probably smoked most of the clutches as well.
Old Jun 1, 2008 | 10:14 AM
ibjags's Avatar
first as RM said
get the code read and go frm there
lease reply and lut is know
by the way you didnt mention mileage
jdzubas
Oct 4, 2015 09:14 AM
Clamdigger
Sep 12, 2015 03:43 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
