Any thoughts on this...... if not its all good
Old Mar 29, 2012 | 09:45 AM
John Fox's Avatar
Default Any thoughts on this...... if not its all good
So some might remember I bought a 99 VDP at auction a few months back that I had seen run and drive (fine), didnt win then bought it the next week but it wasnt running this time as they said the battery was dead and couldn't get it to jump.
Anyway, I have done pretty much everything needed to get it to start including plugs, fuel pump and oiling the cylinders. It will crank and ALMOST catch, actually almost sounds like its running it wants to start so bad but......
Bank 2, #4 cylinder has no compression. All the others are fine and even with one bad one the car should still fire and run even if not on all cylinders. I have recently decided to let a mobile mechanic I know take a shot at it. He pulled the cover yesterday and noticed the lifter on that #4 is not coming up all the way as it should while manually cranking the engine.
So boys and ladies, LOL, any thoughts ? I bought the car cheap enough to part it although it is in very good shape and only has 100K on it and the tensioners have been replaced.
No water in the oil..cranks and gets fuel... so..... what now I ask ?
Old Mar 29, 2012 | 10:30 AM
JimmyL's Avatar
Sounds like a bent valve. Sure the tensioners were replaced ?
Old Mar 29, 2012 | 12:29 PM
Sean B's Avatar
my suggestion,
Cause
...waterpump is the original, impellers have gone, no coolant movement.
Effect
...an overheat event, valve seat dropped, pinned valve.
Fix
...replace head.
Old Mar 29, 2012 | 03:22 PM
yeldogt's Avatar
The aluminum engine does not like to overheat and the valve seats can be affected
Old Mar 29, 2012 | 08:34 PM
John Fox's Avatar
Thank you gentlemen... now to decide if its worth doing the heads (wont do just one) or not.
hunter34
19
Sep 14, 2022 11:09 PM
way2far
Aug 31, 2022 09:26 AM
sogood
Sep 15, 2015 07:35 AM
Bowman
Sep 3, 2015 03:17 PM
XJsc-guy
Sep 2, 2015 11:43 AM
