Anybody have issues dealing with Mina Gallery?
Old Sep 26, 2018 | 01:19 PM
anduha's Avatar
Originally Posted by CharlzO
The idea is that in the shroud that you would couple it with, it would seal against the closed hood, effectively turning into a replacement "box" that the hole in the fender would still direct cooler air into. It's certain to do a better job that way than without any shroud at all, but I do believe it's inherent nature would still introduce slightly warmer temperatures than the stock sealed airbox. That's part of why I took the cone filter off mine (I do miss the look though) and went back to the factory airbox. A high flow filter is in next, which should be a nice bridge between factory and an open cone.
You definitely have the right idea. After reading some of the responses on here I decided to try again with the cold air tube but use the stock air box with a high flow filter. This has proven to be a good compromise, no lean issues and most of the smoothness is retained but with more low end grunt and a punchier feel. With the cone filter it just sounded too loud and rough but to each his own.
Old Oct 1, 2018 | 06:45 PM
harvest14's Avatar
I guess I measured wrong for the Cobra Head elbow. It came the other day and it does not fit. I asked on here if anyone knew the correct size but since I didn’t get an answer I measured myself (incorrectly) and ordered the wrong one!
Old Feb 18, 2019 | 12:55 PM
trottier.ed's Avatar
Default Mina Cust. Serv.
I am a Mina rear exh upgrade (tips and resonators delete) customer. Asked Mina a related question (resonance drone at about 2k rpm in D). Mentioned that I thought Mina tips (coffee cans) were a bit "OTT" (English for Over the Top), and did they have any advice for "restoring" and another Mina exhaust mod? Inbox: Mina crickets since. Considering RE-install resonators/tips, deleting front (large, common) muffler, and replacing with "X" pipe. Are exhaust piping dia. given in "inside" or "outside" dia??? Magna flow has 2.25, 2.5 and 3.0 in X pipes, but would like to "match" my OEM, XJR. Which is it? Info??? Thanks.
axr6
Jul 25, 2022 11:48 PM
multistrada74
Mar 31, 2019 06:36 PM
TreVoRTasmin
Jul 21, 2018 09:22 AM
SlipperyPete
Mar 22, 2016 03:57 PM
2004x-type
Aug 26, 2009 03:54 AM
