Anyone ever had...
Old Apr 14, 2013 | 09:09 PM
coastaljag98's Avatar
Default Anyone ever had...
Subwoofer volume disappear from the head unit menu? I thought because my sub was busted that was why. I just replaced with new and still not showing in menu. I'm guessing new amp?!
Old Apr 16, 2013 | 07:50 AM
Bump
Old Apr 16, 2013 | 10:59 AM
dsnyder586's Avatar
Strange. I would check connections at the amp- is there a hidden setting in the head unit to add/delete the sub?
Old Apr 16, 2013 | 05:20 PM
Red October's Avatar
Replied to this on your other thread-I'd suspect the Amp or wiring near the Amp. If any work was done on the car in the trunk area-fuel tank/pump etc-then it's possible that a wiring fault has been introduced somewhere...
I would carefully check all cables going to the Amp-right from the Amp itself to wherever they go. If the head unit is not recognising the Amp, then it's probably either the Amp itself or the wiring to it-check if any wires are damaged/trapped by the fuel tank etc.
Old Apr 17, 2013 | 02:58 PM
I can unplug the amp and I get no sound. Amp working but just the channel for the sub isn't. I am about to just get a used one and try it. It's 50 bucks so what the heck.
orlee
Oct 11, 2014 01:09 PM
03impala9c1
Feb 17, 2014 04:23 PM
blindside
Jan 22, 2014 02:24 AM
Stormdk
Oct 30, 2013 03:32 PM
quinnjere
Oct 22, 2013 03:36 PM
