Anyone ever remove the entire dash?
Old Apr 29, 2023 | 03:21 PM
pcolapacker's Avatar
Default Anyone ever remove the entire dash?
Think I have all the nuts and bolts off because it moves back a half inch to an inch all around. Don’t know if needs to come off at an angle or some other trick. Trying to double check that no wire loom is stopping it. Full removal not in manual.
Old Apr 29, 2023 | 04:24 PM
Sean B's Avatar
There is a support bracket behind the dash airbag, have you got to that? There's also a central locator tang at the top centre rear of the dash that needs the assembly to come straight out.
Old Apr 29, 2023 | 04:33 PM
Yes on behind airbag. Does the tang just locate or does it have a clip? Thinking might need to disconnect another wire loom.
Old Apr 29, 2023 | 09:18 PM
Addicted2boost's Avatar
Unless your parting out the car, you might want to unbolt the steering column and rest it on a box without disconnecting it from the intermediate shaft. I see two bolts on top already and there’s two more fasteners about a foot down the column from there. I posted pictures years ago from when I did an evaporator. Look up: “Evaporator time.” if you need any other information or just ask here.
ppsales
Jul 13, 2022 10:20 AM
82jaguarxj6
Jan 17, 2015 01:11 AM
macdoesit
May 31, 2013 04:26 AM
osyris
Dec 25, 2012 07:17 PM
fogrocker
Feb 16, 2012 02:08 AM
