Applicable Shock bushings for my climate
Old Jan 17, 2016 | 03:57 PM
etachu's Avatar
Default Applicable Shock bushings for my climate
My front shocks rattle over minor road unevenness. On inspection, noticed the bushings have failed as shown in the photos. It appears the tropical temperature here (Nigeria/West Africa) is affecting the bushings and causing them to melt and fail prematurely.
Is there a type of bushing that is suitable for this climate? Would be such a relief. Car is 2001 XJ8 VDP.
Attached Thumbnails Applicable Shock bushings for my climate-faulty-shock-bushing2.jpg   Applicable Shock bushings for my climate-faulty-shock-bushing3.jpg
Last edited by etachu; Jan 17, 2016 at 04:11 PM. Reason: Seems am unable to insert the photos.
Old Jan 18, 2016 | 12:25 AM
plums's Avatar
Take a look at some of the other threads on the subject.
It appears that you are missing the entire bottom side bushings.
Old Jan 18, 2016 | 10:30 AM
TXE36's Avatar
You can't see the bottom bushing from under the fender. You have to remove the plate from the top. The bottom bushing is on the backside of the plate.
That said, I wish stock bushings were available. I don't like the polys for this as I've had a set go bad in the tropical climate of Texas.
-Mike
Old Jan 18, 2016 | 11:27 AM
Addicted2boost's Avatar
http://m.ebay.com/itm/361440702156?_mwBanner=1
Eurospare makes these. I know it's a little bit of money, but it's an alternative at least.
Old Jan 18, 2016 | 12:30 PM
Mark SF's Avatar
You can sell your old shock mount plates on Ebay, and get a little money back. I think I got $30 for mine. Someone will buy them to fit new bushes to, to minimise downtime. Then they will sell their old plates, and the circle of life continues.
thedugger1
Jan 21, 2016 04:49 PM
cjd777
Jan 20, 2016 03:33 AM
XKR8
Jan 14, 2016 07:15 PM
Doug
Jan 13, 2016 01:47 PM
Dan R
Dec 28, 2015 10:38 AM
