Battery or starter
Old Oct 25, 2019 | 04:57 PM
ant17's Avatar
Default Battery or starter
My 1998 VDP does not get driven much so I try to start it as much as possible. I'm on the 2nd new battery bc the battery keeps getting discharged when parked. I either jump it or place a charger on it. Lately I have noticed even after having the charger on the battery I turn the key and nothing, then after a few times it starts. I'm trying to determine whether its the starter or not and maybe the starter is causing the drain on battery. Any ideas here? Was thinking about replacing the starter.
Old Oct 26, 2019 | 06:52 AM
JagV8's Avatar
You may have a drain. Either follow threads about finding out or put it on a ctek-type device all the time it's stored.
Old Oct 26, 2019 | 03:53 PM
King Charles's Avatar
I keep mine on a NOCO Genius G1100 when not in use.
Amazon Amazon
Old Apr 27, 2020 | 09:30 PM
EXEF's Avatar
I give mine (700 Amp) a charge every month or two so it's always fully topped up. It's important to note that due to the limitations of the current that some of them deliver, they are not intended for directly starting a vehicle immediately on their own but instead, you connect them to your vehicle battery for 5 - 10 minutes to charge it up a little before attempting to crank the engine. I've used mine several times using this method and it's always been successful.
Old Apr 30, 2020 | 08:33 PM
Jagman92's Avatar
ant17,
ive seen similar problems. Firstly, do all the instrument panel lights come on when you turn the key to the ignition on position?
Old May 1, 2020 | 10:51 AM
ant17's Avatar
Originally Posted by Jagman92
ant17,
UPDATE: It WAS the starter. There' s a surface in the drive part that wears down. Once worn bad enough the bendix just spins and never engages. Bought a starter on ebay that was in much better shape.
Starter hasn't missed since.
Old May 1, 2020 | 04:36 PM
Jagman92's Avatar
Good deal. Glad to hear it. Best of luck to you.
jimbo61
Oct 5, 2019 05:03 AM
mrobinson
Nov 18, 2016 07:37 AM
Darrenmb
Nov 15, 2014 01:42 PM
Jsnyder0828
Dec 18, 2013 09:11 AM
kobe3006
Sep 9, 2012 06:19 PM
