Battery tender
Old 07-31-2015, 11:18 AM
smith356's Avatar
Default Battery tender
I'm going away for 3-4 months and the car (98 XJR) will be outside. Since the battery is in the trunk, how can a battery tender be installed without leaving the trunk open ? Your thoughts and experience would be greatly appreciated.
Thanks, Jim
Old 07-31-2015, 11:36 AM
Mark SF's Avatar
You can connect it under the hood. There is a + terminal on the passenger side, at the rear of the inner fender. You have to prise back the little rubber cover. For negative connect to any good ground (I use the shock plate bolts)
I always connect under the hood, as it's more convenient than removing the battery cover.
Old 08-01-2015, 06:01 PM
smith356's Avatar
Mark, "You Da Man !" Thanks, Jim
Msteiner
05-16-2016 12:19 AM
jluckcuck
11-06-2015 07:49 AM
10 XF Premium
10-02-2015 09:22 PM
Swagguar
09-30-2015 01:34 PM
Quick Reply: Battery tender
