Best toe-in setting for XJR?
Old Nov 25, 2015 | 09:23 PM
Mark SF's Avatar
Default Best toe-in setting for XJR?
I've just finished a 5 hour fight to change the track rod ends on the 02 XJR. Totally siezed on the adjustment thread - had to grind slots in them and use a blowtorch.
I have two charges for alignment in the recent service history, to the previous owner, so how did they adjust the toe-in?
Anyway, now I can adjust the toe in properly. Has anyone experimented with the best setting to minimise tram-lining?
Old Nov 25, 2015 | 10:33 PM
convincor's Avatar
Dealer did my alignment just a couple weeks back. Can't tell you what they set it to, but tram-lining is almost non existent. Was terrible before.
Here's specs I had found in a search if it helps.
http://www.jagrepair.com/images/Auto...s-09-2009-.pdf
Old Nov 25, 2015 | 10:41 PM
Mark SF's Avatar
Thanks, that document is just what I needed!
Old Nov 26, 2015 | 05:43 AM
ericjansen's Avatar
I wonder if that document is for x308 considering the date mentioned on the opening page.
Did a lot of reading when I upped my 16" for wider 18" rims, and tram-lining seems more the result from worn suspension, and wider/lower profile tires (especially the 255's).
However, the notorious problem of chaffing the profile from the inner side of the front tires seems to be dramatically reduced by a proper toe.
There are several threads on this matter on this forum.
Pushing the front wheels out while setting toe-in will help in the correct setting.
I did so, and did not find any uneven wear to my new fronts yet, while my previous fronts were down on the thread with the rest of the tires just half worn.
I do have the correct settings somewhere, let me know if you want me to dig them up.
Old Nov 26, 2015 | 06:00 AM
convincor's Avatar
As the introduction states on pg 2
"The date printed on the front cover is the issue date of the
booklet. The booklet will be updated and reissued
periodically to enable the inclusion of new and modified
data."
And thru the specs it list 98-03 XJ, XJR, XK, XKR, XF, S-Type, X-Type up to 2010
Old Nov 26, 2015 | 08:02 AM
ericjansen's Avatar
data."
Then it is now downloaded, and replacing an older version I had.
Thank you Sir.
Alexv12
May 10, 2019 09:04 PM
daro31
Canada
May 12, 2016 04:54 AM
amaezing
Nov 27, 2015 02:24 PM
daro31
Nov 25, 2015 06:53 AM
Pilotman11
Nov 20, 2015 07:49 AM
