bolt pattern?
Old Mar 22, 2008 | 09:43 PM
iamitltproof's Avatar
Default bolt pattern?
i have a 2000 xj8 i know the bolt pattern is 5x120.65. is a 5 x 120 bolt pattern the same just shortened or is it a completely different bolt pattern? thanks in advance
Old Mar 24, 2008 | 08:15 PM
stangman's Avatar
Default RE: bolt pattern?
I see no one has tried to answer your question …so I will try…5 on 120.65 is metric for 5 bolts on a 4 and ¾ inch bolt circle …this was for many years a GM and Jaguar bolt pattern …how ever the Jag has a larger Center Bore diameter ….the hole in the center of the wheel the hub and axel fits through …5 on 120 is a metric bolt pattern ….true the difference between 120.65 and 120.0 is only .65mm or a fraction over 1/16 inch an less than 3/32 if it fit over the bolts it would put a bending stress on the lug bolts causing them to break under high loads such as impact with a pot hole or obstacle…secondly the metric 5 on 120.0 is usually a smaller 7/16 or metric lug bolt as apposed to the ½ inch 5 on 4 ¾
Thanks Jim A
Old Mar 25, 2008 | 09:07 AM
thanks
Old Mar 25, 2008 | 07:49 PM
stangman's Avatar
I will answer that with what I have done ….your results may very and you and you alone are responsible for any actions you make take and the consequences they may cause …I have taken wheels to a machine shop had them open up the bolt holes larger and drilled off center to match 4 3/4 bolt pattern …Drill out the center bore to match Jag bore ….that being said there lots of wheels that have come on the market lately that fit without all this machine work …they have a close +15 +25 +35 mm positive offset and large bore …. the XJ has around a +30 mm positive offset ….. with the smaller offset (+15 +25) you can get a larger wider tire under rear fenders
Jim A.
Old Oct 15, 2019 | 06:46 AM
Vegas_Jag's Avatar
I thought the pattern was 5x108? I'm looking to buy wheels for my 2000 xjr.
Old Oct 15, 2019 | 09:25 AM
M. Stojanovic's Avatar
It is 120.65 (108 from X350) and the choice of aftermarket wheels is somewhat limited. I bought Coventry Whitley 120.65 wheels (made in China, by the way). Plenty on Ebay - https://www.ebay.com/itm/18x8-5-Cove...BdJn-q&vxp=mtr. This seller has many choices of sizes and offsets in 120.65 pcd.
Old Oct 15, 2019 | 10:09 AM
Vegas_Jag's Avatar
Thank you for clarifying that, when I look it up online it says 5x108, now I can order the right wheels!
Cheers!
Old Oct 15, 2019 | 02:30 PM
Vegas_Jag's Avatar
Im looking at two sets of wheels to buy, one store says my 2000 xjr is 5x108 with hubcentric rings, the Coventry wheels store says it's 5x120, same answers online, I need to be sure before I buy.
One store said 5x120 is for 96-09 XK Series.
Anyone know the proper offset on Aftermarket wheels?
Thanx for any input!
Old Oct 15, 2019 | 07:42 PM
Those stores are lousy. This is a good one: https://www.wheel-size.com/size/jaguar/xj/
Johnny V
Jun 21, 2018 06:51 AM
jamdmyers
Mar 15, 2015 02:00 PM
jahummer
Feb 24, 2015 10:39 PM
vandenplas408
Jan 8, 2014 01:52 PM
Gergs
Nov 8, 2010 07:18 PM
