Boot (trunk) lock
Old Jan 3, 2014 | 04:55 AM
kyle04's Avatar
Default Boot (trunk) lock
The boot button does not release the boot lock, the key opens it ok.
I have disconnected the solenoid wire and tested with a meter.
The reading is 0.36 on the 20m amp scale. Its the same with the button pressed and not pressed, ie no change when pressing the button.
Have similar scenario on the Volt scale (not an expert on this).
Does this mean a wiring / button fault father than the solenoid ?
AndyP
Old Jan 3, 2014 | 05:20 AM
jimbov8's Avatar
Hi Andy,
Your most likely cause will be in the area where the wiring enters the boot lid by the hinge.
There's probably a broken wire within that area.
For the actuator you need wires black and orange.
For the switch you need red/green and black/pink.
In both cases the black is ground.
A known common fault.
Hope this helps,
Old Jan 3, 2014 | 07:17 AM
kyle04's Avatar
Thanks jimbov8 - the solenoid is ok as the boot opens remotely with the dash button, and I can hear it activate with this, so will look at switch / wiring as suggested.
Regards
AndyP
dsnyder586
Dec 29, 2024 07:39 PM
BadKat174
May 26, 2023 12:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Ragn0r
Sep 19, 2015 08:39 AM
speacock
Sep 10, 2015 12:14 AM
