bought a xjr with bent valves
Old Mar 11, 2013 | 08:20 PM
99kyxjr's Avatar
Default bought a xjr with bent valves
i am thinking about rebuilding it but havent been able to find a rebuild kit
valves
springs
retainers
piston rings and gasket sets
someone help
Old Mar 11, 2013 | 09:58 PM
dsnyder586's Avatar
rebuilt kit? Just lap those valves, replace the bent ones and put her back together!
Old Mar 11, 2013 | 10:00 PM
dsnyder586's Avatar
If you are thinking of a total rebuild you are in for a $hock- The bottom ends are pretty robust.
Top ends gasket set is available through partsgeek I paid around $300 including shipping with a coupon.
Old Mar 11, 2013 | 11:46 PM
99kyxjr's Avatar
do you think that the pistons might have some damage or??
i rebuilt a few vw 1.8t engine and when valves bent there is no damage to pistons because they are forged
Old Mar 12, 2013 | 12:46 AM
dsnyder586's Avatar
You will know as soon as you pull the head(s). More than likely no.
Old Mar 12, 2013 | 10:06 AM
Red October's Avatar
Check that each piston reaches TDC, because if a piston hits a valve it can also cause the con-rod to bend slightly as well as leaving marks on the piston.
This happened to me on an old BMW years ago. I had the head off to replace a couple of bent valves, but noticed that as I rotated the crankshaft to bring each piston to TDC for decoking, that the front piston was not reaching the same height as the others & was down by about a couple of mm-as well as looking like it was not sitting centrally in the bore.
Sure enough, after dropping the sump & removing the piston & rod from the top of the block, the con-rod was bent in a very slight dog-leg pattern.
Old Mar 12, 2013 | 10:15 AM
dsnyder586's Avatar
Agreed- check with a depth gauge after you pull the heads.
Keep us updated- If I do not get my fix of auto repair successes I start looking at Craigslist. If I start looking at Craigslist I find projects. When I find projects I buy them. When I buy projects my wife gets annoyed. Please don't make me make my wife annoyed.
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
Sprayall
May 30, 2021 08:13 AM
Bowman
Sep 15, 2015 06:54 AM
Sprayall
Sep 3, 2015 07:49 PM
