Brace Question?
Old Apr 25, 2020 | 11:21 PM
Vegas_Jag's Avatar
Default Brace Question?
I'm looking to buy that lower rear member brace.
ebay ad says for 1997 z
X308, I asked if it will fit my 2000 xjr. He didn't know.
Will it fit my car?
Old Apr 27, 2020 | 07:58 AM
ericjansen's Avatar
Explain to me what that brace does the A-frame is not doing already?
IMO useless for our type of suspension.
Old Apr 27, 2020 | 03:58 PM
Vegas_Jag's Avatar
To eliminate a little body roll and stiffen chassis.
Will it fit my 2000 XJR?
Old Apr 27, 2020 | 06:02 PM
ericjansen's Avatar
No offence intended, as I like mod's ...
But in this case, realize that it is waste of money, as you will have to remove the original A frame, which does exactly the same already.
If you want ot stiff up matters, look at thicker sway bars.
And yes, I am 99% sure that a x300 and X308 have the same fitting points for the A frame.
Old Apr 27, 2020 | 11:35 PM
M. Stojanovic's Avatar
The brace will have no effect on the body roll. The body roll is controlled, as Eric mentioned, by the sway bars and by the Adaptive Damping shock absorbers (if you have them).
I also agree that the brace will, most probably, not provide any additional stiffening of the chassis. I consider these braces just a fancy thing to have and only when they can be seen by the drivers behind you.
Mkii250
Apr 12, 2020 07:24 PM
Kongo1
Jun 6, 2018 07:54 PM
bongobrown
Mar 3, 2017 02:56 PM
Dpk2313
US Midwest
Oct 13, 2015 04:39 PM
XJR-99
Aug 28, 2012 01:05 PM
