Brake Fluid Sensor
Old Jan 24, 2019 | 11:06 AM
hstovall1's Avatar
Default Brake Fluid Sensor
I am getting a Low Brake Fluid warning indicator, even though it seems that my reservoir is topped off. I am wondering if I have a bad sensor, and where that sensor lives. I do not see anything called out on the assembly schematic for the brake servo and master cylinder.
Anyone out there experienced this?
Old Jan 24, 2019 | 12:12 PM
Carnival Kid's Avatar
If you remove the large black cover over the brake reservoir, (just one small phillips screw holding it) I'm pretty sure there is a electrical connector on the side of the reservoir to an internal level float.
Maybe disconnect the connector and inspect for a good contact, tap the reservoir to make sure the float is not stuck?
Old Jan 24, 2019 | 03:31 PM
I'm assuming this is the brake fluid level sensor connection?
andrewrichardson
Jul 22, 2013 11:10 AM
Brewtech
Oct 8, 2012 09:43 AM
benebob
Jul 23, 2010 03:40 PM
NMH1977
Nov 30, 2007 09:55 AM
