Brake lights not working
Old Aug 5, 2025 | 09:54 PM
Ant305's Avatar
Default Brake lights not working
Hi everyone, I noticed my brake lights are not working every time when I press the brake pedal, this has caused my car not to be able to get out of park so i have to hit the brakes for a few minutes to get the brake lights to work.
What do you guys recommend to look at first and the steps leading forward?
98 XJR
Anthony
Old Aug 6, 2025 | 02:02 AM
Stu 1986's Avatar
The very first thing to check it’s the brake light switch mounted on the brake pedal. These have been known to become stuck over time, simple to remove and clean and lubricate.
Old Sep 24, 2025 | 04:37 PM
Ant305's Avatar
Finally got around to doing this job, and figured out my switch was indeed bad when I put a multimeter to it.
I went and picked up a used one from a 2000 XJ and the continuity read good but noticed the part numbers were off by the last letter.
My PN - LNB 6420 BA
Junkyard PN - LNB 6420 BB
Will I still be able to use this brake switch?
Old Sep 24, 2025 | 04:49 PM
RandyS's Avatar
Yours is a '98 and the "BB" part is a 2000, but My guess is it will work just fine.
Old Sep 24, 2025 | 04:56 PM
Ant305's Avatar
Ok thank you, it plugs in so I’ll fasten it and hope for the best.
JJS- Florida
May 5, 2023 10:37 PM
wimpertjo
Jun 2, 2021 08:52 PM
Muskoka Jaguar
Nov 10, 2014 08:19 AM
2004xjr
Nov 24, 2011 10:38 PM
bbqit2
May 21, 2009 12:16 AM
