Burning rubber smell under acceleration
Old Feb 12, 2014 | 03:52 PM
princemarko's Avatar
Default Burning rubber smell under acceleration
I have a burning smell under hard acceleration since the exhaust was done. Doesn't look like valve covers, could it be the cat converters damaged or going bad?
Old Feb 12, 2014 | 04:32 PM
Sean B's Avatar
burning rubber and burning oil are distinctly different Marko!
You only need a drop on the manifold for oil to smoke and smell.
How close is the exhaust to the rear tires? I'd guess the gases would be cool enough not to trouble the rear tires though...
S.C. belt slip? tensioners to check?
If the cat's go bad they throw gases off and the O2's would throw a code, fuel trims would also be out of normal range, is it using more fuel? any codes?
hope this helps
Old Feb 13, 2014 | 02:02 AM
sparkenzap's Avatar
Not the tires, right?
Old Feb 13, 2014 | 04:44 AM
parwun's Avatar
nothing is better than smell of tyres in the morning)
Old Feb 13, 2014 | 07:40 AM
Schwabe's Avatar
what do you mean by exhaust done? If it is a new exhaust it would be "patina" burning off.
Old Feb 13, 2014 | 10:48 AM
sparkenzap's Avatar
Is "Patina" a fancy Italian sports car?
Old Feb 13, 2014 | 08:44 PM
Vector's Avatar
I get a "hot" smell from mine under hard acceleration. I decided it was simply the heat from the compressed air coming from the supercharger causing the entire cooling system to heat up fairly rapidly.
Vector
Old Feb 14, 2014 | 06:48 AM
No codes. But the smell is of burning rubber. I opened the hood and it didn't smell at all but the belts.
I upgraded the exhaust to magnaflows, that's when the smell arrived
Old Feb 14, 2014 | 08:51 AM
Schwabe's Avatar
WOW ... patina is the green stuff that forms on copper but now is pretty much used for all kind of grime which is left on machined parts, ie oil, solder, small metal shavings etc ... it is normal for an exhaust to smell when it is new. There is no way for them to have the inside of the exhaust absolutely clean so you smell it burn off. A magnaflo or flowmaster especially if they have any kind of matting inside the muffler.
bdboyle
Sep 16, 2019 05:58 PM
Buckingham
Jul 6, 2016 11:09 AM
Poet
Oct 2, 2015 09:00 AM
rgp
Oct 1, 2015 02:55 AM
