can I refit the OEM parking sensor on my 2000 XJR?
Old Mar 29, 2011 | 04:17 PM
vincent661983's Avatar
Default can I refit the OEM parking sensor on my 2000 XJR?
I would like to know if that is "technically" possible without hustle.Thank you
Old Mar 29, 2011 | 06:10 PM
plums's Avatar
Do you mean "retrofit" as in the model year did not have them?
Old Mar 30, 2011 | 04:20 AM
Cadillac's Avatar
Yup, you can do it . You can also go for aftermarket sensors
Old Mar 30, 2011 | 08:05 AM
Do I just need the sensor and the wire or what else I need
Old Mar 31, 2011 | 04:02 AM
Cadillac's Avatar
Module, sensors , wires and skill . As far as I know you don't need to remove the bumpers . Be careful when drilling the holes I think that's the most important thing
Old Mar 31, 2011 | 09:49 AM
luc's Avatar
luc
Jaguar has/had a kit to retro-fit the "reversing aid" and I have the fitting instructions ( that include a template to drill the holes)
You do have to remove the bumper and the rear parcel shelve.
The kit included:
Sensors (4)
Holders (4)
Wiring harness .Sensor to ECM
Wiring harness. Sounder to ECM
ECM
Sounder
Template
Old Apr 3, 2011 | 08:13 AM
jimlombardi's Avatar
Default Here is another backup sensors thread on the forum
Hi
Check out this other backup sensors thread postings. Shows all the componets and their locations. Also gives information from others who worked on these sensors.
https://www.jaguarforums.com/forum/j...sensors-52429/
Hope this helps.
Jim Lombardi
Old Apr 3, 2011 | 01:03 PM
Sean B's Avatar
there's definitely 2 ways to do it - OEM or aftermarket. I looked at the newer design parking sensor that uses electromagnetic signals, purely to remove the sensor heads, I was toying with the idea of a smooth car, but didn't like filling the holes left behind.
By far the easiest is the kit I mentioned above, there's no holes to drill, and if the install goes well, no more than an hour to do.
Here's a link to a similar kit I looked at, there must be the same kind of system closer to you in the USA
No Holes Parking Sensor | Parking Dynamics Reverse Sensor
If your rear bumper hasn't got holes in it, I'd go for one of those kits. I fitted one to my sister's RR Discovery, they work very well.
Forcedair1
Sep 8, 2025 01:57 PM
Rlover
Mar 30, 2016 10:04 PM
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
pocketrocket
Sep 3, 2015 07:44 PM
