Help! Fluid everywhere x308
Old Apr 3, 2011 | 01:03 PM
pezzonovante88's Avatar
Default Help! Fluid everywhere x308
Just got my 2001 VDP out today. Drove it home from storage (about 10kms) no problems. Normal operating temp, etc. I left it running on my slanted driveway for obviously too long while pumping the tires up. Suddenly steam started pouring out and there was coolant pouring out of the radiator hose that had come detached at the top. The issue is there were two visibly different color fluids splattered about the engine bay (yellow - traditional coolant, and reddish orange - mystery). What am I looking at here?
I will upload photos shortly after I figure out how.
Old Apr 3, 2011 | 02:00 PM
plums's Avatar
Possibly power steering fluid, or automatic transmission fluid.
If one of them has a cooler that is integrated with the radiator then it has burst a seam between the cooler and radiator tank. The higher pressure then pushes it into the radiator and out wherever it can.
Once you get it fixed, you will have to decide whether you trust that the higher pressure prevented infiltration or that you want to do a fluid flush.
Old Apr 3, 2011 | 02:12 PM
Forgive me for I am very newb. But, does that mean that I'm going to have a problem with either my trans or power steering system, as well? I am definitely going to get a coolant flush, anyway.
Old Apr 3, 2011 | 02:34 PM
plums's Avatar
Well, first you have to confirm that a distant guess is correct.
In any case, it would be wise not to start it again until fixed.
Old Apr 3, 2011 | 02:38 PM
I know. Thanks. Its being towed to the Jag store tomorrow morning. BTW, I thought the ZF Trans Esso fluid was honey colored new, then very dark after a few Ks.... Hopefully its nothing big!!!!!!
King Charles
Oct 16, 2015 01:25 AM
adam699
Oct 13, 2015 05:53 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
