Can only get 5L of coolant in.....?
Old Dec 21, 2018 | 07:04 PM
Jagman85's Avatar
Default Can only get 5L of coolant in.....?
Hello everyone,
I have just replaced the tensioners & guides. An epic job as we all know but it now lives again & is running great with the following exception......
Im not sure why I can only get 5 litres of coolant into the system. The water pump is working, same for the thermostat as im getting flow through the expansion tank each time i squeeze a hose or blip the throttle. I did notice that only the upper half of radiator is getting hot so maybe a blockage in the radiator? One hose is nice & toasty but the other hose is not. Am I missing something really basic?
Also, Im getting the restricted performance notification. But that might be from the coolant splashing on the plugs & causing a short because I forgot to do up the coolant filler point before i started it & it spouted up everywhere. Also havent connected the thermofans or temp sensor yet.
Old Dec 21, 2018 | 07:11 PM
ericjansen's Avatar
You will get restricted performance if the sensor is unplugged.
If you drained the coolant through the radiator, you will get less in, as there remains a large amount in the engine itself.
The is an engine drain plug on the side of the block if you want to do a further flush.
Old Dec 21, 2018 | 07:43 PM
Jagman85's Avatar
Ah that explains it. Thank you ^_^
JagXV6
Feb 4, 2025 01:28 PM
Harry Peter Rose
Feb 13, 2018 08:14 PM
murray2200
Oct 28, 2017 03:35 AM
Sentinelist
Aug 26, 2013 09:37 PM
