Can someone tell me what to do?
Old Jul 19, 2008 | 09:49 PM
Markus's Avatar
Default RE: Can someone tell me what to do?
Water pump failure was common with the original design - should have been replaced by now; secondary timing chain tensioners have been redesigned also (twice), and could lead to catastrophic expense if not updated. Nikasil-lined cylinder bores may also be suspect - have the dealer do a "blow-by test." Have them check the suspension bushings. There was a recall on the throttle body; the dealer should confirm that all relevant recalls have been done.
Get the service records if at all possible.
Good luck with it - wonderful cars if properly maintained!
________
1999 XJR
Old Jul 20, 2008 | 04:50 AM
Brake buster's Avatar
being a '99 car, it will have the AJ27 engine over the first V8 for this range which was the AJ26, being an AJ27 means that it has the revised throttle body , and will not require the recall work...also , it will also have second generation tensioners fitted from new, but these also fail,
we are actually on revision 5 now for the tensioners, revision 4 being the metal bodied version
i know this because when i bought my own replacements directly from Jaguar, all the old revisions came up on the screen with the newer ones superseding all the ones before
all the other advice above is spot on....
BB
Old Aug 7, 2008 | 07:52 AM
gatorVDP's Avatar
One more thing tolook for are missing VIN labels. There should be one on each body panel as well as each door. If one is missing, then chances are that panel had to be repainted for one reason or another.
Old Aug 7, 2008 | 12:23 PM
KAZsam's Avatar
Did you test drive it in the rain at night? best time to test drive because you need to turn everything on. Lights, defogger, wipers etc. and you will see if any leaks.
