Can this wheel fixed ?
Old Oct 12, 2020 | 04:36 PM
RA110623's Avatar
Banned
Default Can this wheel fixed ?
Hi guys . I bent my wheels I was driving my car normal speed 40mph then couldn't avoid the hole in the street so tire became flat and wheel Bent now can this be fixed?
Old Oct 12, 2020 | 06:58 PM
jeff xj8's Avatar
i think that bump can be pounded back into shape and the tire re seated, you may want the check its balance. I've seen worse.
jeff xj8
Old Oct 12, 2020 | 07:15 PM
89 Jacobra's Avatar
Active Streak: 30 Days
I'm with jeff xj8, I've seen, and straightened much worse. The way I judge whether Aluminum can be straightened, is to look at the areas where it has bent. If you can see cracks / splitting of the Aluminum. Then it's to far gone, to simply pound it back into shape. That will require professional reconditioning. But what I see here shouldn't be a problem. Hope it helps.
Jack
Old Oct 12, 2020 | 08:33 PM
Addicted2boost's Avatar
A 2x4 and a BFH will straighten that out.
Old Oct 12, 2020 | 11:53 PM
RA110623's Avatar
Banned
Jack
Can't see any cracks it's just the 2 bents I will go to tire shop hopefully get fixed asap. Thanks
Old Oct 14, 2020 | 10:36 PM
Col. Sandurz's Avatar
Pic of wheel? I may have a couple extra depending on location
Old Oct 18, 2020 | 02:13 PM
steven300's Avatar
aluminum has no memory, a pro might get done but don't get your hopes up. IF you straiten it out chances are it will crack, thats not a hard wheel to find,i would replace it. cheaper to replace than paying someone to try to fix it.
Old Oct 18, 2020 | 02:39 PM
RA110623's Avatar
Banned
Fixed it already I wouldn't say it's like the factory work but now the wheel have no bents and works fine .
Thanks for help
LadaXKR
Oct 10, 2017 03:24 AM
ShaunPA
Nov 20, 2016 08:53 PM
XKGuy
May 21, 2013 09:28 PM
exrub
Feb 18, 2011 09:18 PM
Hamish
Aug 19, 2010 10:19 PM
