car lurches when selecting gears
Old Nov 16, 2020 | 11:05 AM
Zlobby's Avatar
Default car lurches when selecting gears
1999 XJR.
When I shift into either drive or reverse, there is a slight clunking sound and the car seems to lurch either forward a bit when put into D, or backwards a bit when put into R. The sound is coming from the rear of the car. This is a new car to me and I plan on getting the transmission fluid changed as I don't know its history. Is this something that a simple trans fluid change could fix, or could it be indicative or something more serious?
Old Nov 16, 2020 | 11:13 AM
NBCat's Avatar
Start with a fluid change and check for stored DTCs.
Old Nov 16, 2020 | 11:21 AM
xalty's Avatar
Could be a lot of things, collapsed transmission mount would be my main suspect.
If you’re close to chicago and need a dipstick for the mercedes transmission I can stop by and give you my spare.
Old Nov 18, 2020 | 12:29 PM
hispeed42's Avatar
Since the noise is coming from the rear of the car, I would check the whole driveline, especially the differential and drive shaft(s) u-joints.
Old Nov 18, 2020 | 12:48 PM
Highhorse's Avatar
I have question, you state it lurches, but then you state the sound is coming from the back? Are you saying you get a clunk noise along with a movement either forward or backward?
After the fluid change and if you still have the issue....a +1 to Marks suggestion. Here's a thread to review, but don't focus on the center bearing (though check it out). Look at the Jurid coupler in Post #3 and Post #13 regarding Universal Joints.
https://www.jaguarforums.com/forum/x...g-info-188400/
If you find you need the Jurid Couplings replaced, be sure to review this thread before attempting the installation....
https://www.jaguarforums.com/forum/x...pshaft-207717/
You can find these along with many other How To's in the ....wait for it ... How To section at the top of the forum. A number of those really need to be retitled, they are a bit long in the tooth and were the first Threads posted.
Nookpad
Feb 7, 2016 09:06 AM
Muti007
Aug 14, 2015 09:39 AM
esloser
Jul 2, 2012 08:14 PM
jaydid2
May 16, 2011 05:52 AM
SleekCat
Apr 30, 2011 07:44 PM
