CEL but Scanner Will Not Connect
Old Mar 22, 2022 | 11:35 PM
Len Apcar's Avatar
Default CEL but Scanner Will Not Connect
This has happened a couple times recently. I have a CEL but when I attach the scanner it doesn't establish contact and no codes read back.
Ideas?.
Old Mar 23, 2022 | 08:29 AM
Jtestrake's Avatar
Try another scanner to see if the problem is with your scanner or with the car’s canbus/electrical system.
Old Mar 23, 2022 | 10:47 AM
pcolapacker's Avatar
This may be a silly question, but in what position is the key? Mine only works in on position or with the car running.
Old Mar 23, 2022 | 12:56 PM
Len Apcar's Avatar
car was running. not a silly question at all
Old Mar 23, 2022 | 01:30 PM
Amphicar770's Avatar
Do you have aftermarket stereo or alarm system components installed? Those will often interfere with scan tools.
Old Mar 23, 2022 | 10:15 PM
Len Apcar's Avatar
I have replaced the speakers only in the front doors. All else is original.
Old Apr 22, 2022 | 09:04 AM
02VDPMiami's Avatar
Were you able to resolve this? I recently purchased my first Jaguar an 02 VDP with 46,000 miles and also had this issue. It was a fuse in the passenger rear footwell fuse area. Sends power to the OBDII port. Check your owners manual for exact fuse number, I don’t recall off hand. Good luck!
Old Apr 22, 2022 | 10:35 PM
Len Apcar's Avatar
Yes, a third scanner worked with the engine off. I had checked the fuses. I think there are two for the Jag Diagnostic System and one for the engine control unit. All fuses were fine.
Good luck to you.
L
Old Apr 23, 2022 | 12:53 PM
Ken Cantor's Avatar
Good luck to you.
L
Would you mind sharing which scanner worked (and which ones didn't)? Thanks...
Old Apr 23, 2022 | 02:40 PM
02VDPMiami's Avatar
Amazon Amazon
i bought this cheap WiFi OBDII dongle and it works fine. Works for iOS with WiFi where most Android ones are Bluetooth. I purchased OBD Fusion for $10 and it works to diagnose and clear codes
XJR Pilot
Aug 10, 2019 11:01 PM
XJ 4Ever
Sep 19, 2017 06:44 PM
01s-type1984
Dec 4, 2011 09:52 AM
K.Westra
Aug 4, 2011 10:11 AM
baycliffpwds
General Tech Help
Sep 18, 2010 02:20 PM
