CEL/Restricted Performance
Old May 15, 2009 | 09:25 AM
Sparkers69's Avatar
Default CEL/Restricted Performance
Guys,
I have been getting the CEL/rest performance lights for well over three months now. My code reader gives me the code P0326 - knock sensor. I have replaced the spark plugs with the NGK iridium type but this has not cured the prob. I was accelerating from about 60 up to 85 the other day and the car started to hesitate and would not accelerate further without jerks/hesitation. The Rest Performance light is the most annoying thing about the car - I have 89K on my 2001 XJR. I cleaned the MAF sensor about 4 months ago, and most recently the air filter. Can the knock sensor/s cause this problem? Could the timing be out? I recently had the secondary chain tensioners replaced - thoughts??
My mechanic told me if I am going to replace one knock sensor I may as well replace both of them as they need to remove the supercharger.
Any ideas?
Thanking you all in advance.
Steve
Old May 15, 2009 | 04:23 PM
wazari's Avatar
It definitely can be the knock sensor. A faulty knock sensor will retard the timing.
Old May 15, 2009 | 07:22 PM
Sparkers69's Avatar
Thanks man - much appreciated.
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
1100me
Oct 1, 2015 11:49 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
