Centre Resonator Delete - Check Engine Light
Old Jul 25, 2019 | 08:13 AM
BritM5's Avatar
Default Centre Resonator Delete - Check Engine Light
Hi, anyone have any experience with deleting the centre resonator on an XJR (01/02) and replacing it with a Magnaflow x-pipe? In this case, doing so seems to have thrown a CEL with code P1647. Said code points to oxygen or Lambda sensors.
Any thoughts much appreciated!
Old Jul 25, 2019 | 09:57 AM
RJ237's Avatar
That code is for the left bank upstream sensor. It may be coincidence, but try swapping the connector with the right bank upper and see if the code reads the same, or just compare the resistance of the two.
Old Jul 25, 2019 | 11:15 AM
Addicted2boost's Avatar
I’m with RJ. Definitely a coincidence. It’s not like you took out a catalytic converter and then your light came on. It’s most likely an open heater circuit within that 02 sensor anyways.
Arqum Usmani
May 17, 2017 10:43 PM
04xtype04
Apr 19, 2014 10:09 PM
Michal
38
Jan 19, 2012 11:42 PM
dag82
Jan 18, 2012 05:18 AM
Jaggyx
Jan 24, 2010 04:07 PM
