change shift position without instrument cluster
Old Jan 30, 2014 | 06:19 PM
iflytb9's Avatar
Default change shift position without instrument cluster
Hey Everyone,
I've been pulling some parts of my 98 vanden plas and storing the parts for use with my XJ8 when needed. Anyway, I pulled the instrument cluster and now I'm unable to shift into another position. Put the cluster back in, and all works fine. Engine starts fine without it. Is there a way to bypass this logic? I'd like to store the cluster, but leave the car in Park until I remove the Transmission.
Thanks!
Old Jan 30, 2014 | 06:28 PM
XKRacer's Avatar
Remove the plastic torx screw on your J gate, stick a small screwdriver down there and it will manually release the car out of park.......
As you fell the stick release pull the screwdriver out
Old Jan 30, 2014 | 06:31 PM
iflytb9's Avatar
Sweet, Thanks!!
Rlover
Mar 30, 2016 10:04 PM
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
martybmw
Sep 4, 2015 11:05 PM
AL NZ
Sep 4, 2015 08:39 PM
