How do I remove this seal on front timing cover?
Old Jan 30, 2014 | 06:36 PM
WaterDragon's Avatar
Default How do I remove this seal on front timing cover?
Please see attached pics
Does this just press out from back to front? or is there another way to do this properly?
Thanks in advance
Attached Thumbnails How do I remove this seal on front timing cover?-2014-01-30-16.32.36.jpg   How do I remove this seal on front timing cover?-2014-01-30-16.32.55.jpg
Old Jan 30, 2014 | 07:19 PM
aholbro1's Avatar
It comes out the front on the AJ-16:
https://www.jaguarforums.com/forum/x...enewal-101564/
I should think it would be the same on the V-8. Not sure if you can drive it out the back or not - I know the AJ-16 doesn't have a lip and you can drive it all the way through on installation if you are not careful - in which case, as the Marines put it, you've "(screwed) yourself!" With the front cover off, you won't have an issue if you go too far or if the little spring pops out the back - much easier fix with the cover removed.
Just take care that your front cover is supported evenly all the way around - you don't want to crack a piece off trying to drive the seal out.
Old Jan 30, 2014 | 07:32 PM
avt007's Avatar
I don't recall any lip. I drove it out back to front using a large socket. Just refer to your picture when driving the new one in.
Old Jan 31, 2014 | 01:54 AM
XKRacer's Avatar
Push it out either way, I just use a big screw driver and the palm of my hand, putting the new one in is where you have to be careful
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
peterg19
Aug 28, 2015 08:42 AM
anthawk
UK & Eire
Aug 27, 2015 05:56 PM
