Changing brake fluid - how much needed?
Old Mar 17, 2013 | 06:00 AM
Vector's Avatar
Default Changing brake fluid - how much needed?
Hi All,
Jag recommends that the brake fluid be changed every three years and it is time for me to renew the brake fluid on my XJR.
How much (Super) DOT 4 fluid does it take to replace/flush all the fluid in the vehicle out to each caliper?
Vector
Old Mar 17, 2013 | 08:17 AM
RJ237's Avatar
I have found 1 qt. to be sufficient if you first draw the fluid out of the reservoir.
Old Mar 18, 2013 | 12:41 AM
xjay8's Avatar
Vector....2 litres should do it for a full flush.
Taking into acount that if you have Brembo calipers, they will have two bleed nipples each at front.
Bleed sequence is:
LHF - RHF LHR - RHR
If you use the conventional method via pedal use full long strokes gently....don't go pumping away madly.
A pressure bleeder (easily available via Amazon) is definately a better way to go for a complete flush and doesn't run the risk of damage to the master cyclinder bore/seals by constant pedalling.
BrentGardner
29
Dec 16, 2024 12:13 AM
Rupesh
Mar 25, 2016 03:33 PM
niner nellie
Sep 1, 2015 10:53 PM
nelsonht
Aug 30, 2015 06:01 AM
divingmom
Aug 25, 2015 07:54 PM
