Changing just one shock absobrer???
Old Apr 3, 2011 | 02:36 PM
mzs_biteme's Avatar
Default Changing just one shock absobrer???
99 VDP...
Had both front shock absorbers replaced back in November '10, and one of them (passenger side) just busted, leaking shock fluid all over. Since they're still relatively new, I shouldn't have to replace both of them, should I? BTW, I used the KYB KG5783, and plan on using them again... Cheap...
Old Apr 3, 2011 | 02:49 PM
pezzonovante88's Avatar
I certainly wouldn't think you would have to replace the other one, as well unless you put a ridiculous amount of mileage on since the original replacement. But, no, definitely just the one will be fine, I'm sure.
Old Apr 3, 2011 | 09:01 PM
motorcarman's Avatar
Here is the Jaguar policy for the XJ8 damper replacement criteria in TSB form.
bob gauff
File Type: pdf
Old Apr 3, 2011 | 10:33 PM
H20boy's Avatar
KYB, not that much of a savings over a bilstein (maybe $25 each), as bilsteins can be purchased now for under $100. But, in this case, replace same with same, and hope for the best.
Neil1664
Jan 20, 2022 08:59 PM
ym37tech
Feb 8, 2016 01:04 PM
OkieTim
Sep 8, 2015 04:48 PM
EZDriver
Sep 8, 2015 09:25 AM
Busa R
Sep 3, 2015 05:01 PM
