Check Rear Lights?
Old Sep 20, 2014 | 01:47 PM
Len Apcar's Avatar
Default Check Rear Lights?
Anyone get this note up front but all rear lights -- brake, directionals, license plate -- and side markers work.
Stumped.
Old Sep 21, 2014 | 11:33 PM
jimlombardi's Avatar
Are you sure the brake lights are working properly by having someone look at the brake lights come on and off as someone uses the brake pedal??
The Security and Locking Control Module (SLCM) is known to fail and cause one or both rear brake light to stay on (malfunction).
Jim Lombardi
Old Sep 22, 2014 | 10:49 AM
Len Apcar's Avatar
Yes, I am sure. I followed my wife out of the driveway today and all three brake lights worked properly while she drove.
The message is intermittent so I suspect a glitch. I assume you get the message if a bulb is bad, too, yes?
Old Sep 22, 2014 | 12:24 PM
Cabezagrande's Avatar
I'm having this same issue. Intermittent warning message, had people outside the car check it several times when the message is present at various times and conditions, all lights fully functional. Could it just be the SLCM? It was very infrequent for a long time, but it's getting worse now (more frequent message, still no problem with the lights). I'm going to replace all of the light bulbs and see if it helps.
Old Sep 22, 2014 | 01:45 PM
Probesport's Avatar
Check and make sure the proper bulbs are in there. Perhaps the wrong wattage incandescent or non canbus LED's are installed giving that message.
Old Sep 22, 2014 | 06:36 PM
Here are some information from another post on the forum by member testpoint:
Does your cruise control work?? If does not work, then the "check rear lights" might be caused by intermittent failing brake pedal light switch. First try cleaning the contacts on the switch. If that does not fix it, then try replacing the switch with a new one.
Jim Lombardi
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
