Check rear lights message
Old Sep 16, 2015 | 03:15 PM
remccallum's Avatar
Default Check rear lights message
Is there a way to de- activate this message, I upgraded the lights to LED.
Old Sep 16, 2015 | 07:36 PM
andrew lowe's Avatar
Sounds like you got the wrong leds!?!?
You need the can bus compatible leds, I believe these have a resistor built into them.
Old Sep 17, 2015 | 05:23 AM
sparkenzap's Avatar
The lamp current detect is a hardware circuit in the various modules that light lamps, and AFAIK, you could only deactivate it by cutting the leads on the boards. The better method is to install load resistors in parallel with the bulbs so that the correct current is still being drawn. If you can't find properly sized load resisitors from the LED lamp guys, then you need to find the current draw of the original bulbs and use Ohm's law to calculate the required resistor for each circuit.
Old Sep 17, 2015 | 07:33 PM
remccallum's Avatar
Default check rear lights msg
The bulbs are can bus bulbs, just checked with the manufacturer and he said for my car I will still need resistors.
thank you for your help guys.
Old Sep 18, 2015 | 08:24 AM
sparkenzap's Avatar
CAN bus bulbs, huh? I strongly suggest you do not take ANY technical advice from that guy! I mean it! That is absurd and one of the dumbest things I have ever heard.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
Isoruku
Jun 19, 2020 12:54 PM
tony bosco
Sep 1, 2015 02:06 PM
tonydbaker
Aug 30, 2015 11:02 PM
