Checking Secondary Timing Chain Tensioners
Got the gasket kit yesterday and installed the right side today. Bit of a job getting it all in there, but its done and so far after a couple short drives, no obvious leaks. I had a bit of an oil smell that I traced back to a bit evaporating off the back of the head, I torqued all of the bolts down to 80 in/lb when I reinstalled, found a tiny weep of oil on the lower bolt on the back of the valve cover so I upped that one bolt to 95 in/lb and ran it for awhile in the driveway without any scent at all. I'll take it for a run tomorrow and see if it holds.
Haven't pulled the left front wheel yet to check the engine serial number. Too excited to drive the car now.
Did this gasket kit come with 28 new rubber washers that go under each bolt head? If not, that can be a reason why you had an oil leak as they apply pressure on the valve (cam) covers.
I ran it for awhile in the driveway last night, no oil smell. Going for a drive later this morning so we'll see if we get any further weeping or scent from the gasket today.
Bcrary3
Aug 31, 2015 11:29 AM
1stone98xjr
Mar 8, 2013 11:52 AM
