Climate control display backlight
Old Nov 5, 2010 | 08:34 PM
Mafioso68's Avatar
Unhappy Climate control display backlight
2001 XJR, the backlight on my climate control display decided not to come on anymore. What can I do to rectify the situation? Do I have to replace the entire unit? Can the display be removed and a new one installed? Is it repairable? Any help is much appreciated.
Old Nov 6, 2010 | 01:13 PM
sogood's Avatar
Default Backlight problems
This sound like an issue that arises with the xj6, as it did on my 97 x300. The problem on mine was sorted by removing the centre ski slope in the console and then removing the display, held in place ( on mine at least) by 4 easily visible screws. The electrical connection consists of a ribbon type connector, with a row of contacts embedded in it. This slots into the rear of the display unit and is where the problem usually exists. Clean the electrical connections on both the strip and the unit and then using a strip of cardboard as a packer, refit the connector. The strip of cardboard takes up the slack between the connection and may need a little trial and error to get it right. Try it out before final reassembly!! Once sorted, the card can be held in place with some tape. Hope this is clear but will become more so when you have a look see.
Old Nov 6, 2010 | 01:32 PM
Mafioso68's Avatar
Thank you kindly good sir, I will try it and let you know. Much obliged.
Old Nov 9, 2010 | 10:24 PM
Mafioso68's Avatar
Alright, found the problem: It's two "Neo Wedge LED bulbs" type B (T4)that illuminate the screen. They are available at http://autolumination.com/74.htm or through the dealership.
2001 White XJ8
Feb 25, 2021 05:02 PM
Chris Hinton
Sep 24, 2015 08:38 PM
al_roethlisberger
Sep 21, 2015 08:15 PM
Johnken
Sep 15, 2015 05:46 PM
tberg
Sep 7, 2015 07:32 AM
