Clock Light in 1998 xjr??
Old Dec 30, 2007 | 12:08 PM
drog321's Avatar
Default Clock Light in 1998 xjr??
Is the clock in an xjr supposed to light up when the headlights are on?
I looked in a 98-03 VDP and its light also didn't turn on.
Old Jan 2, 2008 | 08:24 AM
drog321's Avatar
Default RE: Clock Light in 1998 xjr??
Is there a light??? No responses yet - this seems like it should be an easy one.
Thanks all! I want to get this answered prior to ripping up the dash.
Old Jan 2, 2008 | 10:56 AM
ken@britishparts.com's Avatar
Jaguar part number for the bulb is LNC5180AA. Get one from your local dealer.
Old Jan 2, 2008 | 04:34 PM
drog321's Avatar
thanks -i got this fixed.
by an odd coincidince, i actually use your austin location for service and I called to ask you a question about a jag headlight last Friday
Old Mar 17, 2008 | 06:08 PM
jag_genius's Avatar
remove the wood trim .. comes out towards you .. just pry with something plastic under the wood. after wood out remove 4 screws then the vent comes out and it's behind it.. simple to do. becareful with the wood and your dash.
Old Mar 20, 2008 | 11:01 AM
The_Ikon's Avatar
Do we just use a small flat head screw driver? I also have climate control display bulbs out and j-shifter lights out as well. Do they use the same bulbs?
Old Mar 20, 2008 | 01:48 PM
jag_genius's Avatar
use plastic to pry.. if climate control bulbs are out they are different. you will have to remove shifter surround then wood slope .. then radio must come out . havent seen a shifter one out.. but i assume it's similar to the climate control
Old Mar 20, 2008 | 06:28 PM
FactoryJaguarTech's Avatar
Dealer will be able to supply all of them. The shifter bulbs are the same as door switches. I forget the part number. I wanted to change my colour but am having difficulty now sourcing the bulbs.
Old Mar 23, 2008 | 03:23 PM
The_Ikon's Avatar
ORIGINAL: jag_genius
Plastic?
Old Mar 23, 2008 | 03:24 PM
The_Ikon's Avatar
ORIGINAL: FactoryJaguarTech
Thanks!!
Old Mar 23, 2008 | 05:06 PM
Plastic trim tool he means.
Old Mar 23, 2008 | 06:23 PM
jag_genius's Avatar
some people call it a bone tool
Jpav27
Jul 31, 2022 06:43 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
arnoldmilk
Sep 3, 2015 07:42 PM
